Date/Time: Wed, 25 Nov 2026 16:39:16 +0000
SPX500 Price
View Count: 524
| [2025-07-10 17:23:27] |
| User789550 - Posts: 18 |
Hello, Is there a way to adjust the price on SPX500 to match cash/US500 which is 5 points lower ? Tried Edit->Adjust Data-->Add/Subtract amount But does not work Thanks |
| [2025-07-10 19:46:57] |
The best way to do this is to use the "Spreadsheet Formula - Bar" study and adjust each of the Open/High/Low/Close values by the amount you want to shift. For example, for the Open, you would enter the following formula: =O - 5 You can then set the "Spreadsheet Formula - Bar" to be the Main Price Graph to view it by itself. Refer to the following: Spreadsheet Formula (Bar) Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
