Date/Time: Wed, 25 Nov 2026 16:39:17 +0000
Premarket chart
View Count: 570
| [2025-07-10 12:46:43] |
| User793936 - Posts: 17 |
helloo, is this possible to notmalise charts in premarkets so there will not be such shadows starting from 08 00 until open 09 30 ? on nasdaq/nyse/amex/ look today for safx.nq ticker as example |
| [2025-07-10 14:09:42] |
What you are seeing is the data as we get it from the exchange. We do not know why those bars show as they do, but we do not want to change it, as this is the official data we receive.
| [2025-07-11 12:24:18] |
but is there posibility to filter them out like other trading platforms do? das platform or sterling also get this data from exchange, but they have posibility to filter them.
| [2025-07-11 14:32:53] |
| Sierra_Chart Engineering - Posts: 25481 |
No. We are not going to tinker around with the filtering. Inevitably we would end up filtering trades that should not be filtered. The filtering rules are followed according to industry specifications and it is done right. The only thing to check is to make sure, that you are not including Odd lot trades: Chart Settings: Include Odd Lot Equity Trades (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-18 12:55:31] |
but maybe you should try it. Other programs all have this function. I have checked and have this function disabled, which you recommended to me. Everyone can decide for himself whether he wants to see it on the chart or not, as it is clear that it is a single print. Another question is whether it is possible to remove or manually modify the candle that appears every day at 08 00 EST time and its volume. this again complicates the reading of the chart.
| [2025-07-18 18:18:57] |
Yes you can edit the Intraday data. Refer to: Intraday Data Editor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
