Date/Time: Wed, 25 Nov 2026 16:39:16 +0000
v2772: Strange bug with sc.UseTool / DRAWING_RECTANGLE_EXT_HIGHLIGHT
View Count: 663
| [2025-07-09 16:49:36] |
| User907968 - Posts: 887 |
Updated to v2772 and studies built in earlier version that use DRAWING_RECTANGLE_EXT_HIGHLIGHT (and maybe other types but not tested) exhibit strange behavior. 1. When tool.AddAsUserDrawnDrawing = 0, the rectangle is displayed hollow with a mid-line (unexpected outcome), whereas in v2771 the exact same code produces a filled rectangle with no mid-line (expected outcome). 2. When tool.AddAsUserDrawnDrawing = 1, the drawings disappear from the chart completely Reverted to v2771 and expected behavior is restored. |
| [2025-07-09 17:20:44] |
This was something introduced in 2772 and has been fixed with the current release (v 2773). Please follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-09 17:25:23] |
Can confirm that all is good again in v2773. You guys are the best, thanks! |
