Date/Time: Wed, 25 Nov 2026 16:39:16 +0000
Can't find horizontal scrollbar
View Count: 566
| [2025-07-09 14:57:26] |
| User119701 - Posts: 3 |
Hi, Based on my setting i should have a horizontal scrollbar to scroll left and right but I cant find the scrollbar.[image: image.png] [image: image.png] |
| [2025-07-09 14:58:29] |
| Sierra_Chart Engineering - Posts: 25481 |
Enable the scrollbar for the chart from the Chart menu: Chart Menu: Show Scrollbar (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-09 14:59:18] |
Make sure the option for "Chart >> Show Scrollbar" is enabled. Refer to the following: Chart Menu: Show Scrollbar (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
