Date/Time: Wed, 25 Nov 2026 16:39:20 +0000
price retracement
View Count: 419
[2025-07-09 00:04:14]
User318521 - Posts: 52
Is there a way that you guys could make the dialnal line that appears on the price retracement tool while finding the two destinantion points a permanent option with all the same character feateres as the other lines of the tool.
thanks
[2025-07-09 14:04:57]
You can adjust how that line appears. In the Drawing Properties window under the "Levels" tab the "Level 1" options apply to that line.
