Date/Time: Wed, 25 Nov 2026 16:39:13 +0000
2772 version crashing
View Count: 453
| [2025-07-09 00:04:01] |
| UserAR - Posts: 102 |
I installed the update and now sierra crashes while loading and then exits. Can I go back to the previous version? Thanks |
| [2025-07-09 04:17:48] |
| Sierra_Chart Engineering - Posts: 25481 |
Yes. Follow the instructions here: Software Download: Software Rollback Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
