Date/Time: Wed, 25 Nov 2026 16:39:13 +0000
Account connection
View Count: 495
| [2025-07-08 15:18:38] |
| User577837 - Posts: 8 |
Good Morning, My apologies. It looks like I am connected as I received a statement from AMP this morning and I see my trades taken. I didn't think I was connected because when I pulled up the Trade Activity Log yesterday and reviewed the Total Commissions within the report it showed 0.00. I don't think this report is able to connect with AMP to pull the data if I am interpreting this correctly. Thank you, B. |
| [2025-07-08 15:46:54] |
Are you able to see the actual trades done in the Trade Activity Log? With regards to commissions, you need to specify the amount and have it added to your trades. There is no way for Sierra Chart to get the commission amounts from your broker. Refer to the following: Trade Activity Log: Use Commission For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
