Date/Time: Wed, 25 Nov 2026 16:39:19 +0000
Does Sierra Chart Support Per-Entry Break-Even Stops?
View Count: 459
| [2025-07-07 21:41:14] |
| User855512 - Posts: 1 |
Hi everyone, I'm wondering if Sierra Chart supports a specific type of stop management: When I add to an existing futures position, I want to be able to set a break-even stop based on each individual entry, rather than the average price of the overall position. For example, if I add a second contract later in the move, I’d like that second contract to have its own stop move to break-even after a set number of ticks, independent of the first. Some platforms (like Tradovate) handle this natively, treating each add-on like a separate trade with its own stop logic. Is this possible in Sierra Chart either through built-in order management, or perhaps scripting with strategies? If so, any guidance or examples would be appreciated. Thanks in advance! |
| [2025-07-08 14:47:07] |
| Sierra_Chart Engineering - Posts: 25481 |
Really this should just be a case, where you do not want to use Scale In functionality: Attached Orders: Scaling In So you want to keep that disabled. In this case every new order has its own Attached Orders. So this is already supported what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-08 14:47:23
