Date/Time: Fri, 28 Nov 2025 21:22:52 +0000
Minor UI Glitch
View Count: 254
| [2025-07-07 17:41:22] |
| User925540 - Posts: 100 |
Hi I think there is a minor UI bug in the activity log. Going to a "Trades" tab, scrolling all the way to the bottom, the assumption is that the row showing "Total" would be the last line, but it seems the scroll to the bottom goes to somewhere mid page. User needs to scroll up a bit to get it to adjust correctly and show the last line. I've noticed that for many versions including the latest. |
| [2025-07-07 18:00:46] |
| John - SC Support - Posts: 43196 |
Please get us an image of what you are referring to, as we are not fully understanding. Follow these instructions to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-08 19:12:02] |
| Sierra_Chart Engineering - Posts: 21574 |
This will be resolved in the next release.
| [2025-07-08 19:21:30] |
Thank you very much. Sorry for the delay in replying, the system I use to login to SC was having issues so I couldn't reproduce the problem and grab the images. I'll install the next release and recheck. Date Time Of Last Edit: 2025-07-08 19:22:18
| [2025-07-09 00:42:17] |
The issue is no longer observed in version 2772. Thank you. |
| [2025-07-09 03:07:31] |
Yes we did resolve that.
