Date/Time: Wed, 25 Nov 2026 20:51:58 +0000
Intraday Data File Management > Auto Compress Every Days
View Count: 393
| [2025-07-07 15:52:45] |
| User100912 - Posts: 131 |
There appears to be a glitch in this dialog box where it isn't possible to set it to auto compress every N days. Instead there is an input box next to "Delay Between Processing Records Batch in MS:" |
| [2025-07-07 17:54:51] |
| John - SC Support - Posts: 48658 |
There is no glitch. The way the window is setup, it does look like there should be something after "Auto Compress Every Days", but there is not - that is just informational. The controls are within the rest of the options on that page. Refer to the information at the following link: Intraday Data File Management For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
