Date/Time: Wed, 25 Nov 2026 20:51:58 +0000
Pulling/Stacking understanding
View Count: 843
| [2025-07-04 19:19:16] |
| blt - Posts: 233 |
... SIERRA CHART SUPPORT be so kind and help me sorted out following: In all three (3): Sum Bid Pull/Stack Sum Ask Pull/Stack Ask/Bid Pull/Stack Sum Diff. Pulling carries "-" and Stacking carries "+" sign example: on Bid side: Bid pull =40 Bid stack=100 Sum Bid Pull/Stack=60 (-40+100=60) on Ask side: Ask pull =90 Ask stuck=10 Sum Ask Pull/Stack=-80 (-90+10=-80) now: Ask/Bid Pull/Stack Sum Diff=[Sum Ask Pull/Stack]-[Sum Bid Pull/Stack]=-140 (-80-60=-140) Is this reasoning correct ?! Thank you |
| [2025-07-07 15:32:50] |
| John - SC Support - Posts: 48658 |
In general your logic is correct. Just keep in mind that the actual calculation of the "Sum Bid/Ask Pullling Stacking" is just a summation of the actual numbers that are seen in the DOM. There is not a separate calculation for the Pulling and a separate calculation for the Stacking and then those added up.
