Date/Time: Thu, 03 Jul 2025 01:12:53 +0000
How to fix Studies overlapping each others?
View Count: 14
[2025-07-02 14:17:15] |
User246578 - Posts: 57 |
Hi there, If DOM uses more than 2 VBP's studies, then one will overlap the other one. There are only 2 positional choices exist for VBP's to be placed - as Left or Right. There is no problem to use one or two studies. The problem comes if the third VBP is placed on the same DOM, cause it has no choice as to be placed to the Right or Left - meaning it'll overlap with the VBP that is already there. Questions: 1. Is there a way to position more then 2 VBP's on the same DOM => one next to each other to avoid overlopping? 2. Or, is there a way to use some sort of VBP's displacement to prevent them from overlapping each others? Attached is an example showing 3 VBP's used on the same DOM as: POC on the right side. Total Volume and Numbers of Trades on the left side are overlapping each other. Thank you |
[2025-07-02 16:21:30] |
John - SC Support - Posts: 40722 |
Refer to the following: Volume By Price Study: Allow Side-By-Side Profiles on Right Side For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
