Date/Time: Wed, 25 Nov 2026 16:39:12 +0000
IBKR Data feed, Current daily volume bar incorrect
View Count: 727
| [2025-07-01 20:00:58] |
| Jeff Li - Posts: 74 |
Hello, I am using ibkr data feed, the volume study for the daily bars are wrong.. Please help. Chartbook attached. |
Attachment Deleted. Private File |
| [2025-07-01 20:20:13] |
We do not have access to the Interactive Brokers data ourselves, so the chartbook will not do us any good. We need to see an image of what you are seeing and an explanation of the issue related to what is in the image. Given what you state, however, we wonder if you are looking at a Volume by Price Profile for a Daily Historical Chart. Refer to the following if this is the case: Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-02 13:38:39] |
| Sierra_Chart Engineering - Posts: 25481 |
Provide an image of the chart or Trade DOM, by following these *exact* instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-02 14:24:49] |
https://www.sierrachart.com/image.php?Image=1751466253843.png You can see that the volume for the current day is incorrect and also not showing. |
| [2025-07-02 14:34:50] |
What is the symbol of the chart? We have no idea. These specific instructions must be followed. : Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Otherwise, we cannot help with this and a screenshot is just not helpful at all to us Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-02 14:35:39
| [2025-07-02 15:21:44] |
sorry, its WULF. but the volume issue is for all symbols.
| [2025-07-02 15:22:47] |
The issues is that: 1. the current daily volume candle doesnt show in chart area 2 2. The daily volume for the current bar is incorrect. it is much lower than what it is supposed to be. |
| [2025-07-02 15:34:14] |
On the chart, after the symbol WULF, do you see [M]?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-02 15:34:20
| [2025-07-02 17:45:15] |
Yes, the title is WULF[M]/WULF-STK-SMART-USD [CBV-D] Daily #16 L:27 | Terawulf INC Edit: I think i am using the Denali USD consolidated tape with ibkr as my broker. Date Time Of Last Edit: 2025-07-02 17:45:51
| [2025-07-02 22:31:00] |
Go to that chart and check this setting in Chart >> Chart Settings and let us know how it is set: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-08 16:08:53] |
thanks, i turned it on and it fixed the issue. I am wondering if there is an option to hide the trade/only symbol from the title? And also maybe the company name as well? From WULF[M]/WULF-STK-SMART-USD [CBV-D] Daily #16 L:27 | Terawulf INC to WULF[M] [CBV-D] Daily #16 L:27 | Terawulf INC or to WULF[M][CBV-D] Daily #16 L:27 |
| [2025-07-08 17:37:38] |
No.
| [2025-07-09 13:18:05] |
no worries. Can you please let me know how to enable continuous contracts on Futures using IBKR? I have the option enabled but NQ only loads the 202509 contract Symbol: NQ-202509-CME Automatically rollover futures symbol = Yes Continuous Contract - Volume based rollover back adjusted. |
| [2025-07-09 13:27:10] |
You definitively cannot do continuous futures contracts, with Interactive Brokers unless you are using the Denali Exchange Data Feed and you are not for CME futures. You need to pay the real-time exchange fee for this: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
