Date/Time: Wed, 25 Nov 2026 20:52:01 +0000
Export trade activity.
View Count: 1654
| [2025-07-01 18:30:30] |
| cherioJJ - Posts: 27 |
Hi, Is there a way to export Trade Activity Log > "Trades" to a direct .csv file? Using File > Save Log As The options for File Type available are only "Text Files (*.txt)" and "All Files (*.*)" I also tried saving it as File Type: All Files, with the end in ".csv" But it just compiles all the data into one row. Is there a way to save it as .csv where it neatly shows the value in their respective rows and columns? |
| [2025-07-01 19:13:02] |
| John - SC Support - Posts: 48658 |
When you save the Trades tab using the "Save Log As" option and saving as a "Text File" the information is tab-delimited. So you can use this to get it imported into another program.
