Date/Time: Wed, 25 Nov 2026 16:25:15 +0000
Last price not displayed on chart
View Count: 538
| [2025-07-01 14:26:19] |
| User942750 - Posts: 5 |
Hi, The last price on candlestick charts is not being displayed within the chart or when I stretch the x-axis is shown at the very top. Please see the screenshots attached including my current scale settings. Kind regards, Emman |
| [2025-07-01 16:29:46] |
In the image you show of your chart, the most recent bar is off the top of the screen, so the current price will not be visible. Make sure the bars are in view and if there is still a problem then let us know.
| [2025-07-22 13:31:39] |
Hi, unfortunately this problem still persists. Even though I have my settings set to "Keep the last bar within view". I also tried automatic range and to re-centre to the last bar or price but the most recent bar remains off the top of the screen. Could you please advise. Regards. |
Private File |
| [2025-07-22 15:40:29] |
Have you reset the scales? Refer to the following: Chart Scale and Scale Adjusting: Resetting the Scale If you still have an issue, then we need to see an image of the chart by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
