Date/Time: Wed, 25 Nov 2026 20:52:06 +0000
Price only shows at 1 point increments I want it to show per tick .25
View Count: 656
| [2025-07-01 09:39:08] |
| ryoburto - Posts: 10 |
Im struggling with the above title, thanks.
Date Time Of Last Edit: 2025-07-01 09:39:24
| [2025-07-01 14:44:38] |
| John - SC Support - Posts: 48658 |
For one thing, you have the "Chart >> Chart Settings >> Symbol >> Price Display Format" set to 1. So you are not seeing the decimal places displayed with the prices. You will need to change this so you can see the prices to the number of digits you want. Refer to the following: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Then, to force the system to use a particular increment for the pricing levels, refer to the following: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Keep in mind that with the Scale Increment, as you compress the prices (increase the overall size of the range of values), the numbers will adjust so that you are not overlapping prices, regardless of how you have the Scale Increment. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-02 10:30:37] |
Im still struggling with that, im only getting delta and volume for every point move and not tick move and the same with the footprint, I want values to show for every tick move. See attached current, thanks.
Attachment Deleted. |
| [2025-07-02 15:23:31] |
What is "Chart >> Chart Settings >> Symbol >> Tick Size" set to?
| [2025-07-02 16:12:43] |
0.25
| [2025-07-02 16:43:56] |
What is "Chart >> Chart Settings >> Chart Data >> Volume at Price Multiplier for Intraday Chart" set to?
