Date/Time: Wed, 25 Nov 2026 20:51:47 +0000
Delta profil reset button
View Count: 999
[2025-07-01 07:44:48]
User334419 - Posts: 19
I would like to have the delta profile on the DOM and, more importantly, be able to create a delta profile remainder.
I managed to configure the volume by price to put it in delta profile format, and I found a study called "volume by price reset button" so I could reset it.
I configured this study to call the volume by price, then I configured a keyboard shortcut in global settings to activate the study, and it doesn't work.
Thank you for your help.
[2025-07-01 14:38:53]
John - SC Support - Posts: 48658
Are you stating that you created a keyboard shortcut for the "Volume by Price Reset Button" and it is not working? If so, then did you use the Keyboard Shortcut option for "Custom Study Control Bar Button Keyboard Shortcuts"?
