Date/Time: Wed, 25 Nov 2026 16:39:11 +0000
[Request]: Modify rectangle middle line & key command for constant range
View Count: 435
[2025-07-01 05:34:12]
WayneL - Posts: 1
There are two requests that would make my life a little easier, if at all possible.
1) The rectangle tool currently does not have any way to modify the middle line separately from the rectangle tool itself. If my line style is dotted, so is my middle line. If my line width is 3, so is my middle line. Can functionality be added to have separate properties for the mid line width/style/color?
2) The other request is I often use the reset constant range (Chart -> Scale -> Reset constant range). I wanted to add a key command to this but this currently is not an option to do so as the Selected Command box is blank. Could this be added?
[2025-07-08 22:52:31]
Sierra_Chart Engineering - Posts: 25481
1) This is a feature request and has been noted. We can not say when we would get to any particular request.
2) We are looking this over.
[2025-07-08 23:52:15]
2. This will be resolved in the next release.
