Date/Time: Wed, 25 Nov 2026 20:52:05 +0000
[Programming Help] - Implementation of AddAndManageSingleTextDrawingForStudy()
View Count: 868
[2025-07-01 00:23:12]
gambotage - Posts: 39
Hi guys,
I wanted to get clarification on why sc.AddAndManageSingleTextDrawingForStudy() is rendering output repeatedly to itself. Can you do a quick code review and offer any suggestions. I'm also experiencing performance issues once the study renders, guessing it renders every time the chart updates (300ms) per per Chart Settings > Performance.
What I'd like is the following:
1. A single stationary text label that supports transparency if user-preferred.
2. It populates the label if the chart is either fully loaded OR on bar close (or bar open if they're synonymous) for efficiency reasons if possible, & will render output of the last bar's data value calculations if looking back at historical data (I know s_UseTool doesn't appear to show historical values when backscrolling from current bar).
Here's a simple implementation:
if (sc.GetBarHasClosedStatus(sc.Index) == BHCS_BAR_HAS_CLOSED) { // Update label on bar close?
sc,
false,
Input_HorizontalPosition.GetInt(),
Input_VerticalPosition.GetInt(),
Subgraph_TextDisplay,
true, // transparent label background enabled
text,
sc.DrawStudyUnderneathMainPriceGraph ? 0 : 1
Thanks in advance!
imagetext-label.png / V - Attached On 2025-07-01 00:16:11 UTC - Size: 105 KB - 283 views
