Date/Time: Tue, 17 Nov 2026 18:09:16 +0000
Missing Tickers in the available Stock Catalog
View Count: 564
| [2025-06-30 19:51:45] |
| User137454 - Posts: 1 |
To whom it may concern, I’m trying to replicate my TradingView watchlist in Sierra Chart, but several tickers (e.g. ABNB, RDDT, DASH, RBLX) do not appear under US Equities – Consolidated Tape (Delayed/Realtime) or NASDAQ TotalView. Currently, only AAPL shows up in my symbol list under US Equities - Consolidated Tape. Steps Taken So Far: Confirmed SC Data [data] is selected in Global Settings → Data/Trade Service Settings Disabled “Use Custom Symbol Settings Values” in Global Settings → Symbol Settings Deleted CustomSymbolSettings.cqg.xml from C:\SierraChart\SymbolSettings\ Expected Behavior: After connecting, the master symbol list (thousands of tickers) should download automatically and be visible under: SC Data [data] → US Equities – Consolidated Tape (Delayed/Realtime) SC Data [data] → NASDAQ TotalView Actual Behavior: Only AAPL is ever listed under US Equities Consolidated Tape, and NASDAQ TotalView is missing plenty of Tickers, including but not limited to ABNB, DASH, RDDT, and RBLX. Typing “ABNB” for example into Find Symbol → Selected Symbol does not pull it in, and charts for manually entered symbols show no data. Request: Please verify that my account entitlements (Integrated Standard) include full access to the U.S. Consolidated Tape and TotalView symbol lists. Advise on any additional configuration steps or server-side settings I may be missing. If there’s a server-side issue or provisioning delay, please correct it so that my data feed can download the full master symbol list on connect. Thank you for your prompt assistance—I will be relying on Sierra Chart for live trading and need these symbols available immediately. Date Time Of Last Edit: 2025-06-30 19:52:55
| [2025-06-30 19:59:09] |
| John - SC Support - Posts: 48555 |
There is no issue. Not all stocks are listed. You just need to enter the stock symbol as you need it into the "Selected Symbol" field on the "Find Symbol" window. So for ABNB you will enter ABNB to get the data from our U.S. Equities Consolidated Tape exchange. You will enter ABNB-NQTV to get the data from our NASDAQ TotalView exchange. And you will enter ABNB_MBO to get the combined U.S. Equities Consolidated Tape with the Market Depth from the NASDAQ TotalView. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
