Date/Time: Wed, 25 Nov 2026 23:00:18 +0000
Spot-Quoted futures (SQF)
View Count: 1341
| [2025-06-30 15:57:45] |
| Flawless Cowboy - Posts: 22 |
Will Sierra Chart be listing the CME's new Spot-Quoted futures products?
| [2025-07-08 17:03:27] |
| User753526 - Posts: 87 |
I also had the same question. I found a listing of SP?## under the CME heading on Symbol but when opening a DOM it priced it from 0 going to negatives below and positives above. I believe the code is QSPX for SPX Quoted Futures but could not find them listed on Sierra Chart. |
| [2025-07-11 19:48:13] |
| Sierra_Chart Engineering - Posts: 25484 |
We will get these particular symbols set up over the weekend.
| [2025-11-23 04:19:45] |
| sqrtltrds - Posts: 4 |
Hey there, Were these ever added? I am curious about them but also see no data still in the platform. |
| [2025-11-25 07:02:30] |
These symbols are unusual in the way that they work. We have to spend some time going over this. They actually, do have a delivery month, and they roll over once a year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-25 17:45:46] |
Understood! Thank you for the update. Do you know if there is any rough timeline on when they might be made available? If not, I understand.
| [2025-12-09 20:37:56] |
These should be available next week.
| [2025-12-09 20:40:31] |
Fantastic, thank you!
| [2026-01-05 22:09:56] |
Hi there, curious if there's been any update on these?
| [2026-01-05 22:55:49] |
| User677437 - Posts: 102 |
Yes, I'm also interested in Spot Quoted Futures. Spot SP500 Spot Nasdaq Spot Russell Spot Dow Spot BTC Spot Ether Spot SOL Spot XRP That's the whole cme spot quoted futures market. |
| [2026-02-13 20:07:30] |
| User542502 - Posts: 25 |
I am also curious if there's been any update on spot-quoted futures?
| [2026-02-13 23:07:47] |
We have added support for these for Teton order routing. Although the clearing firms have to allow them. We need to check to make sure all the settings are updated to actually enable trading. There is a different symbol the exchange uses for margin for these. So that has to be set correctly.
| [2026-02-14 15:34:44] |
I can't find any of the new sqf symbols in the symbol list (Sierra Chart Data Service). When will it be available?
| [2026-02-16 15:19:54] |
These have only been added for Teton order routing at this time. We are working on getting it added for other services.
