Date/Time: Wed, 25 Nov 2026 20:51:49 +0000
Why 'Number Bars Calculated Values' is Not Working After Upgrading to Package 10 from 5?
View Count: 741
[2025-06-28 12:20:46]
User01110 - Posts: 3
Hi how i changed my package to 10 from 5 i want to know why is it says number bars calculated values does not support whats the diffrence between 5 and 10 i just started trading fx i was trading crypto on 5 and now i changed to 10 idk realy
[2025-06-28 20:01:52]
This should be supported. We need to check on this. We will get back to you on this.
[2025-06-28 21:04:16]
User584084 - Posts: 348
Package 11 or 12 are required for Numbers Bars.
Description of Service Packages and Pricing: Integrated Sierra Chart with Advanced Features (Service Package 11)
Date Time Of Last Edit: 2025-06-28 21:06:57
[2025-06-28 21:28:52]
No this is not true. Service Package 5 supports Numbers Bars:
Description of Service Packages and Pricing: Base Standard Sierra Chart (Service Package 3)
But it is correct that if you are using the "Integrated" packages, then you do need to be on one of the "Advanced" packages to have access to the Numbers Bars Calculated Values. In other words, packages 5, 11, and 12 have support for this.
Date Time Of Last Edit: 2025-06-30 13:54:29
