Date/Time: Wed, 25 Nov 2026 20:52:02 +0000
vwap study question
View Count: 651
[2025-06-27 16:21:52]
coachted - Posts: 545
is the vwap output calcualtion effected by the time frame chart in which the study is placed
[2025-06-27 16:26:11]
John - SC Support - Posts: 48658
Refer to the information here:
Volume Weighted Average Price (VWAP) with Standard Deviation Lines: Differences Between VWAP and Standard Deviation Lines On Different Timeframe Bars
[2025-06-27 18:16:07]
is there documentation on how the vwap calcualted on bid volume is constructed....as of rt now i am trying to use it and it is resulting in the same value as total volume...
Date Time Of Last Edit: 2025-06-27 18:16:24
[2025-06-27 20:13:37]
in addition i just created my own anchored vwap and have it one of my machines how do i get it to my other machime
[2025-06-27 20:51:56]
There is no special documentation for this. Just what is already documented here:
Note the documentation on that page for the "Volume Type to Use" that states the following:
"When using either Bid Volume or Ask Volume the option for Base on Underlying Data must be set to Yes or the calculation will be based on the Total Volume."
Even then, when using the Bid or Ask volumes, they will be very similar to the Total Volume. This is just due to the fact that the relative values among these three items is not that different for each period.
If this is a custom study, then you need to put the .dll file in the 'Data' folder on the other system. Refer to the following:
How to Use an Advanced Custom Study or a Study Collection: Manually Installing Advanced Custom Study Related Files
