Date/Time: Wed, 25 Nov 2026 20:52:00 +0000
Question on 2 different subscriptions of Sierra on 1 PC.
View Count: 541
| [2025-06-27 14:42:11] |
| User566779 - Posts: 31 |
Can my brother and I share the one PC with completely separate Sierra Subscriptions and Denali feeds but the same broker? My brother and I both have separate Sierra subscriptions with separate Denali feeds and separate broker accounts, but we both use the same broker. He lives some distance away but when he is here, I want to have a copy of his Sierra on my PC running at the same time as my copy is running with each of us using 2 of the 4 monitors. So, we want to trade from both Sierra accounts at the same time and as we trade long term swings, sharing the one mouse and keyboard is not a problem. Can this work? Both Sierra installations use the same broker, but separate broker accounts, and separate Sierra accounts, and separate Danali-Teton feeds? IF so, is there an easy way to port his Sierra setup complete with broker connections to my PC, or does he have to do a new install and manually set up all the broker and Denali and CME permissions? |
| [2025-06-27 14:47:32] |
| John - SC Support - Posts: 48658 |
In order to have your brother use your computer to run Sierra Chart for his information and trading account, you will need to install a second Sierra Chart on that computer. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart You will then setup that second installation for his setup and brokerage account. You can have both installations running at the same time and getting data from our Denali Exchange Data Feed at the same time. This is not a problem. Also, if he wants to have the same chartbooks and settings as his other system, he will need to move some files from the one system to this new installation. Refer to the following: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
