Date/Time: Wed, 25 Nov 2026 20:51:57 +0000
Can I display the Trade Entry Price (J48) from Spreadsheet System for Trading on a chart?
View Count: 479
| [2025-06-26 20:50:48] |
| TraderBake - Posts: 63 |
I tried it with "Text Display from Spreadsheet", but it does not work. I have the correct spreadsheet and I can display "A1" or every other cell with a Text. But Cells with numbers like j48 dont work. |
| [2025-06-26 21:07:30] |
| John - SC Support - Posts: 48658 |
The purpose of the "Text Display from Spreadsheet" is to be able to display a cell that contains text from a spreadsheet. In order to display a value that is a number, you can just reference the cell into one of the "Formula" columns and then pick up that information from the subgraph associated with that column. For example, to get the information from cell J48 into a subgraph, enter the following into one of the formula columns (Columns K through Z by default), let's say cell T3: =$J$48 Then use the "Text Display for Study", or whatever other study you want to use to display the information, and reference the subgraph for Column T (SG10). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-27 07:44:30] |
Thank you John, that worked.
