Date/Time: Tue, 17 Nov 2026 18:08:44 +0000
The chart is not loading
View Count: 465
| [2025-06-26 17:44:47] |
| User324678 - Posts: 1 |
hi ...ihave problem...The software gives a message that it cannot connect to the data feed and the chart cannot be loaded...Gold Futures Chart Service Package: 10 - Integrated Standard 2025-06-26 17:29:29.653 | Software version: 2767 64-bit 2025-06-26 17:29:29.653 | Primary Thread ID: 6128 2025-06-26 17:29:29.653 | Usage end date: 2025-07-12 2025-06-26 17:29:29.653 | Enabled for: Sierra Chart Historical Data Service. 2025-06-26 17:29:29.653 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-06-26 17:29:29.653 | Enabled for: Delayed Denali Exchange Data Feed. 2025-06-26 17:29:29.653 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-06-26 17:29:29.653 | Current selected Data/Trading service: SC Data 2025-06-26 17:29:29.653 | Custom symbol settings values: enabled 2025-06-26 17:29:29.653 | Chart Update Interval: 400 2025-06-26 17:29:29.653 | Intraday Data Storage Time Unit: 1 2025-06-26 17:29:29.653 | Time Zone: +00:00:00 (UTC+00) 2025-06-26 17:29:29.653 | 2025-06-26 17:29:29 Local computer time in UTC 2025-06-26 17:29:29.653 | 2025-06-26 17:29:29 Local computer time in SC Time Zone 2025-06-26 17:29:29.653 | 2025-06-26 17:23:53 Server time in UTC 2025-06-26 17:29:29.653 | Local computer UTC time and Server UTC time difference: 2 seconds. 2025-06-26 17:29:29.653 | Program path: E:\SierraChart\ 2025-06-26 17:29:29.653 | Data Files path: E:\SierraChart\Data\ 2025-06-26 17:29:29.653 | OS Version Number: 10.0 2025-06-26 17:29:29.653 | Locale Setting: C 2025-06-26 17:29:29.653 | DLLs: UserContributedStudies_64.dll 2025-06-26 17:29:29.653 | Allowed protected custom studies: 2025-06-26 17:29:29.653 | Crash reporter started: true 2025-06-26 17:29:29.653 | 2025-06-26 17:29:35.264 | Socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:29:35.264 | Socket (2) | Write has completed. Shutdown being performed. 2025-06-26 17:29:35.264 | Socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:29:35.264 | Socket (2) | Closed. 2025-06-26 17:29:43.215 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:29:43.215 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:29:43.215 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:29:43.215 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:29:43.215 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:29:43.215 | DTC Client socket (3) | Closed. 2025-06-26 17:29:43.215 | Delayed Data Feed | Failed connections: 7 2025-06-26 17:29:43.215 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:29:43.215 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:29:43.215 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:29:44.974 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:29:44.974 | DTC Client socket (1) | Write has completed. Shutdown being performed. 2025-06-26 17:29:44.974 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:29:44.975 | DTC Client socket (1) | Closed. 2025-06-26 17:29:45.110 | Delayed Data Feed | Did not receive Encoding Response from server. Disconnecting. * 2025-06-26 17:29:45.110 | Delayed Data Feed | Waiting for socket receive thread to end 2025-06-26 17:29:45.111 | DTC Client socket (4) | CloseSocket call. 2025-06-26 17:29:45.111 | DTC Client socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 2025-06-26 17:29:45.111 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:29:45.111 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:29:48.216 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-06-26 17:29:48.216 | DTC Client socket (1) | Creating socket. 2025-06-26 17:29:48.217 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:29:48.217 | DTC Client socket (1) | Connecting to IP: 64.152.155.116. 2025-06-26 17:29:48.758 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:29:48.758 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:29:48.758 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:29:50.114 | Delayed Data Feed | Connecting to the server ds25.sierracharts.com. Port 10043 2025-06-26 17:29:50.115 | DTC Client socket (2) | Creating socket. 2025-06-26 17:29:50.115 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:29:50.115 | DTC Client socket (2) | Connecting to IP: 64.152.155.20. 2025-06-26 17:29:50.415 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:29:50.415 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:29:50.415 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:30:07.497 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:30:07.497 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:30:07.497 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:30:07.497 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:30:07.498 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:30:07.498 | DTC Client socket (1) | Closed. 2025-06-26 17:30:07.498 | Delayed Data Feed | Failed connections: 8 2025-06-26 17:30:07.498 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:30:07.498 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:30:07.498 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:30:08.656 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:30:08.656 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:30:08.656 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:30:08.656 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:30:08.656 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:30:08.656 | DTC Client socket (2) | Closed. 2025-06-26 17:30:08.656 | Delayed Data Feed | Failed connections: 21 2025-06-26 17:30:08.656 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:30:08.656 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:30:08.656 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:30:12.486 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2025-06-26 17:30:12.487 | DTC Client socket (1) | Creating socket. 2025-06-26 17:30:12.487 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:30:12.487 | DTC Client socket (1) | Connecting to IP: 69.39.70.245. 2025-06-26 17:30:12.732 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:30:12.732 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:30:12.733 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:30:13.646 | Delayed Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 10043 2025-06-26 17:30:13.647 | DTC Client socket (2) | Creating socket. 2025-06-26 17:30:13.647 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:30:13.647 | DTC Client socket (2) | Connecting to IP: 64.152.155.21. 2025-06-26 17:30:13.899 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:30:13.899 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:30:13.899 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:30:31.853 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:30:31.853 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:30:31.853 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:30:31.853 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:30:31.853 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:30:31.853 | DTC Client socket (1) | Closed. 2025-06-26 17:30:31.853 | Delayed Data Feed | Failed connections: 9 2025-06-26 17:30:31.853 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:30:31.853 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:30:31.853 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:30:32.588 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:30:32.588 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:30:32.588 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:30:32.588 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:30:32.588 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:30:32.588 | DTC Client socket (2) | Closed. 2025-06-26 17:30:32.588 | Delayed Data Feed | Failed connections: 22 2025-06-26 17:30:32.588 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:30:32.588 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:30:32.588 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:30:36.844 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2025-06-26 17:30:36.844 | DTC Client socket (1) | Creating socket. 2025-06-26 17:30:36.845 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:30:36.845 | DTC Client socket (1) | Connecting to IP: 67.214.125.11. 2025-06-26 17:30:37.016 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:30:37.016 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:30:37.016 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:30:37.584 | Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 2025-06-26 17:30:37.584 | DTC Client socket (2) | Creating socket. 2025-06-26 17:30:37.584 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:30:37.584 | DTC Client socket (2) | Connecting to IP: 67.214.125.5. 2025-06-26 17:30:37.820 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:30:37.820 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:30:37.820 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:30:45.186 | DTC Client socket (4) | Timed out waiting for final send. Canceling I/O. 2025-06-26 17:30:45.187 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-06-26 17:30:45.187 | DTC Client socket (4) | Write has completed. Shutdown being performed. 2025-06-26 17:30:45.187 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:30:45.187 | DTC Client socket (4) | Closed. 2025-06-26 17:30:55.176 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:30:55.176 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:30:55.176 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:30:55.176 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:30:55.176 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:30:55.176 | DTC Client socket (1) | Closed. 2025-06-26 17:30:55.176 | Delayed Data Feed | Failed connections: 10 2025-06-26 17:30:55.176 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:30:55.176 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:30:55.176 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:30:56.735 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:30:56.736 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:30:56.736 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:30:56.736 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:30:56.736 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:30:56.736 | DTC Client socket (2) | Closed. 2025-06-26 17:30:56.736 | Delayed Data Feed | Failed connections: 23 2025-06-26 17:30:56.736 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:30:56.736 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:30:56.736 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:31:00.155 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-06-26 17:31:00.156 | DTC Client socket (1) | Creating socket. 2025-06-26 17:31:00.156 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:31:00.156 | DTC Client socket (1) | Connecting to IP: 64.152.155.116. 2025-06-26 17:31:00.339 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:31:00.339 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:31:00.339 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:31:01.718 | Delayed Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10043 2025-06-26 17:31:01.719 | DTC Client socket (2) | Creating socket. 2025-06-26 17:31:01.719 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:31:01.719 | DTC Client socket (2) | Connecting to IP: 69.39.70.249. 2025-06-26 17:31:02.057 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:31:02.057 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:31:02.057 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:31:18.696 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:31:18.696 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:31:18.696 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:31:18.696 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:31:18.696 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:31:18.696 | DTC Client socket (1) | Closed. 2025-06-26 17:31:18.696 | Delayed Data Feed | Failed connections: 11 2025-06-26 17:31:18.696 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:31:18.696 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:31:18.696 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:31:22.049 | Delayed Data Feed | Did not receive Encoding Response from server. Disconnecting. * 2025-06-26 17:31:22.049 | Delayed Data Feed | Waiting for socket receive thread to end 2025-06-26 17:31:22.050 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:31:22.050 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:31:22.050 | DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2025-06-26 17:31:22.050 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:31:23.696 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2025-06-26 17:31:23.697 | DTC Client socket (1) | Creating socket. 2025-06-26 17:31:23.697 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:31:23.697 | DTC Client socket (1) | Connecting to IP: 69.39.70.245. 2025-06-26 17:31:23.794 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:31:23.794 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:31:23.794 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:31:27.056 | Delayed Data Feed | Connecting to the server ds32.sierracharts.com. Port 10043 2025-06-26 17:31:27.056 | DTC Client socket (3) | Creating socket. 2025-06-26 17:31:27.056 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:31:27.056 | DTC Client socket (3) | Connecting to IP: 69.39.70.248. 2025-06-26 17:31:27.469 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:31:27.469 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:31:27.469 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:31:41.736 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:31:41.736 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:31:41.736 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:31:41.736 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:31:41.736 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:31:41.736 | DTC Client socket (1) | Closed. 2025-06-26 17:31:41.737 | Delayed Data Feed | Failed connections: 12 2025-06-26 17:31:41.737 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:31:41.737 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:31:41.737 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:31:44.776 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:31:44.776 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:31:44.776 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:31:44.776 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:31:44.776 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:31:44.776 | DTC Client socket (3) | Closed. 2025-06-26 17:31:44.777 | Delayed Data Feed | Failed connections: 24 2025-06-26 17:31:44.777 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:31:44.777 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:31:44.777 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:31:46.735 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2025-06-26 17:31:46.736 | DTC Client socket (1) | Creating socket. 2025-06-26 17:31:46.736 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:31:46.736 | DTC Client socket (1) | Connecting to IP: 67.214.125.11. 2025-06-26 17:31:46.944 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:31:46.944 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:31:46.944 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:31:49.766 | Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 2025-06-26 17:31:49.767 | DTC Client socket (3) | Creating socket. 2025-06-26 17:31:49.767 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:31:49.767 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2025-06-26 17:31:50.057 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:31:50.057 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:31:50.057 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:04.336 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:04.336 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:32:04.336 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:32:04.336 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:04.337 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:04.337 | DTC Client socket (1) | Closed. 2025-06-26 17:32:04.337 | Delayed Data Feed | Failed connections: 13 2025-06-26 17:32:04.337 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:04.337 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:04.337 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:05.163 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:32:05.163 | DTC Client socket (2) | Write has completed. Shutdown being performed. 2025-06-26 17:32:05.163 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:05.163 | DTC Client socket (2) | Closed. 2025-06-26 17:32:07.497 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:07.497 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:32:07.497 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:32:07.497 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:07.497 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:07.497 | DTC Client socket (3) | Closed. 2025-06-26 17:32:07.497 | Delayed Data Feed | Failed connections: 25 2025-06-26 17:32:07.497 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:07.497 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:07.497 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:09.334 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-06-26 17:32:09.335 | DTC Client socket (1) | Creating socket. 2025-06-26 17:32:09.335 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:32:09.335 | DTC Client socket (1) | Connecting to IP: 64.152.155.116. 2025-06-26 17:32:09.786 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:09.786 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:09.786 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:10.058 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:32:10.058 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:32:10.058 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:10.058 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:10.058 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:10.058 | Delayed Data Feed | Failed connections: 14 2025-06-26 17:32:10.058 | DTC Client socket (1) | Closed. 2025-06-26 17:32:10.058 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:10.058 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:10.058 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:12.491 | Delayed Data Feed | Connecting to the server ds25.sierracharts.com. Port 10043 2025-06-26 17:32:12.491 | DTC Client socket (1) | Creating socket. 2025-06-26 17:32:12.491 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:32:12.491 | DTC Client socket (1) | Connecting to IP: 64.152.155.20. 2025-06-26 17:32:12.897 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:12.897 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:12.897 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:13.137 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:32:13.137 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:32:13.137 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:13.137 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:13.138 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:13.138 | DTC Client socket (1) | Closed. 2025-06-26 17:32:13.138 | Delayed Data Feed | Failed connections: 26 2025-06-26 17:32:13.138 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:13.138 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:13.138 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:15.063 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2025-06-26 17:32:15.063 | DTC Client socket (1) | Creating socket. 2025-06-26 17:32:15.063 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:32:15.063 | DTC Client socket (1) | Connecting to IP: 69.39.70.245. 2025-06-26 17:32:15.462 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:15.462 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:15.462 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:18.127 | Delayed Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 10043 2025-06-26 17:32:18.127 | DTC Client socket (2) | Creating socket. 2025-06-26 17:32:18.127 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:32:18.127 | DTC Client socket (2) | Connecting to IP: 64.152.155.21. 2025-06-26 17:32:18.621 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:18.621 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:18.622 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:18.896 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:32:18.897 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:32:18.897 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:18.897 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:18.897 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:18.897 | DTC Client socket (2) | Closed. 2025-06-26 17:32:18.897 | Delayed Data Feed | Failed connections: 27 2025-06-26 17:32:18.897 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:18.897 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:18.897 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:23.891 | Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 2025-06-26 17:32:23.892 | DTC Client socket (2) | Creating socket. 2025-06-26 17:32:23.892 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:32:23.892 | DTC Client socket (2) | Connecting to IP: 67.214.125.5. 2025-06-26 17:32:24.297 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:24.297 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:24.297 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:24.486 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:32:24.486 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:24.486 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:32:24.486 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:24.487 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:24.487 | DTC Client socket (2) | Closed. 2025-06-26 17:32:24.487 | Delayed Data Feed | Failed connections: 28 2025-06-26 17:32:24.487 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:24.487 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:24.487 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:29.492 | Delayed Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10043 2025-06-26 17:32:29.492 | DTC Client socket (2) | Creating socket. 2025-06-26 17:32:29.492 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:32:29.492 | DTC Client socket (2) | Connecting to IP: 69.39.70.249. 2025-06-26 17:32:29.888 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:29.888 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:29.889 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:30.097 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:32:30.097 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:32:30.097 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:30.097 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:30.097 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:30.097 | DTC Client socket (2) | Closed. 2025-06-26 17:32:30.097 | Delayed Data Feed | Failed connections: 29 2025-06-26 17:32:30.097 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:30.097 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:30.097 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:35.079 | Delayed Data Feed | Connecting to the server ds32.sierracharts.com. Port 10043 2025-06-26 17:32:35.080 | DTC Client socket (2) | Creating socket. 2025-06-26 17:32:35.080 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:32:35.080 | DTC Client socket (2) | Connecting to IP: 69.39.70.248. 2025-06-26 17:32:35.456 | Delayed Data Feed | Did not receive Encoding Response from server. Disconnecting. * 2025-06-26 17:32:35.456 | Delayed Data Feed | Waiting for socket receive thread to end 2025-06-26 17:32:35.456 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:32:35.456 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:35.456 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:35.456 | DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2025-06-26 17:32:35.553 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:35.553 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:35.553 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:35.791 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:32:35.791 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:32:35.791 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:35.791 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:35.791 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:35.791 | DTC Client socket (2) | Closed. 2025-06-26 17:32:35.792 | Delayed Data Feed | Failed connections: 30 2025-06-26 17:32:35.792 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:35.792 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:35.792 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:40.449 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2025-06-26 17:32:40.451 | DTC Client socket (2) | Creating socket. 2025-06-26 17:32:40.451 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:32:40.451 | DTC Client socket (2) | Connecting to IP: 67.214.125.11. 2025-06-26 17:32:40.780 | Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 2025-06-26 17:32:40.781 | DTC Client socket (3) | Creating socket. 2025-06-26 17:32:40.781 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:32:40.781 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2025-06-26 17:32:40.941 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:40.941 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:40.941 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:41.203 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:32:41.203 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:41.203 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:32:41.203 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:41.203 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:41.203 | DTC Client socket (2) | Closed. 2025-06-26 17:32:41.203 | Delayed Data Feed | Failed connections: 15 2025-06-26 17:32:41.203 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:41.203 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:41.203 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:41.244 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:41.244 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:41.245 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:41.504 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:32:41.504 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:32:41.504 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:41.504 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:41.505 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:41.505 | DTC Client socket (3) | Closed. 2025-06-26 17:32:41.505 | Delayed Data Feed | Failed connections: 31 2025-06-26 17:32:41.505 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:41.505 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:41.505 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:46.210 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-06-26 17:32:46.210 | DTC Client socket (2) | Creating socket. 2025-06-26 17:32:46.210 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:32:46.210 | DTC Client socket (2) | Connecting to IP: 64.152.155.116. 2025-06-26 17:32:46.492 | Delayed Data Feed | Connecting to the server ds25.sierracharts.com. Port 10043 2025-06-26 17:32:46.492 | DTC Client socket (3) | Creating socket. 2025-06-26 17:32:46.492 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:32:46.492 | DTC Client socket (3) | Connecting to IP: 64.152.155.20. 2025-06-26 17:32:46.697 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:46.697 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:46.697 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:46.978 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:46.978 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:46.978 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:32:46.978 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:46.978 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:46.978 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:32:46.978 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:46.978 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:46.978 | DTC Client socket (2) | Closed. 2025-06-26 17:32:46.978 | Delayed Data Feed | Failed connections: 16 2025-06-26 17:32:46.978 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:46.978 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:46.978 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:47.279 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:32:47.279 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:32:47.279 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:47.279 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:47.279 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:47.279 | DTC Client socket (3) | Closed. 2025-06-26 17:32:47.280 | Delayed Data Feed | Failed connections: 32 2025-06-26 17:32:47.280 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:47.280 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:47.280 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:51.968 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2025-06-26 17:32:51.969 | DTC Client socket (2) | Creating socket. 2025-06-26 17:32:51.969 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:32:51.969 | DTC Client socket (2) | Connecting to IP: 69.39.70.245. 2025-06-26 17:32:52.265 | Delayed Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 10043 2025-06-26 17:32:52.266 | DTC Client socket (3) | Creating socket. 2025-06-26 17:32:52.266 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:32:52.266 | DTC Client socket (3) | Connecting to IP: 64.152.155.21. 2025-06-26 17:32:52.367 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:52.367 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:52.367 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:52.577 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:32:52.577 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:52.577 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:32:52.577 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:52.577 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:52.577 | DTC Client socket (2) | Closed. 2025-06-26 17:32:52.578 | Delayed Data Feed | Failed connections: 17 2025-06-26 17:32:52.578 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:52.578 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:52.578 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:52.666 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:52.666 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:52.666 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:52.859 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:32:52.859 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:32:52.859 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:52.859 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:52.859 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:52.859 | DTC Client socket (3) | Closed. 2025-06-26 17:32:52.859 | Delayed Data Feed | Failed connections: 33 2025-06-26 17:32:52.859 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:52.859 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:52.859 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:57.586 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2025-06-26 17:32:57.587 | DTC Client socket (2) | Creating socket. 2025-06-26 17:32:57.587 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:32:57.587 | DTC Client socket (2) | Connecting to IP: 67.214.125.11. 2025-06-26 17:32:57.862 | Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 2025-06-26 17:32:57.862 | DTC Client socket (3) | Creating socket. 2025-06-26 17:32:57.862 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:32:57.862 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2025-06-26 17:32:57.978 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:57.978 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:57.978 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:58.200 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:32:58.200 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:58.200 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:32:58.200 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:58.200 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:58.200 | Delayed Data Feed | Failed connections: 18 2025-06-26 17:32:58.200 | DTC Client socket (2) | Closed. 2025-06-26 17:32:58.201 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:58.201 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:58.201 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:32:58.288 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:32:58.288 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:32:58.288 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:32:58.538 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:32:58.539 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:32:58.539 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:32:58.539 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:32:58.539 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:32:58.539 | DTC Client socket (3) | Closed. 2025-06-26 17:32:58.539 | Delayed Data Feed | Failed connections: 34 2025-06-26 17:32:58.539 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:32:58.539 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:32:58.539 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:33:03.198 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-06-26 17:33:03.198 | DTC Client socket (2) | Creating socket. 2025-06-26 17:33:03.199 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:33:03.199 | DTC Client socket (2) | Connecting to IP: 64.152.155.116. 2025-06-26 17:33:03.542 | Delayed Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10043 2025-06-26 17:33:03.542 | DTC Client socket (3) | Creating socket. 2025-06-26 17:33:03.542 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:33:03.542 | DTC Client socket (3) | Connecting to IP: 69.39.70.249. 2025-06-26 17:33:03.571 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:33:03.571 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:33:03.571 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:33:03.719 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:33:03.719 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:33:03.719 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:33:03.719 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:33:03.720 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:33:03.720 | DTC Client socket (2) | Closed. 2025-06-26 17:33:03.720 | Delayed Data Feed | Failed connections: 19 2025-06-26 17:33:03.720 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:33:03.720 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:33:03.720 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:33:03.900 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:33:03.900 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:33:03.900 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:33:04.037 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:33:04.037 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:33:04.037 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:33:04.037 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:33:04.037 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:33:04.037 | DTC Client socket (3) | Closed. 2025-06-26 17:33:04.038 | Delayed Data Feed | Failed connections: 35 2025-06-26 17:33:04.038 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:33:04.038 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:33:04.038 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:33:08.706 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2025-06-26 17:33:08.706 | DTC Client socket (2) | Creating socket. 2025-06-26 17:33:08.706 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:33:08.706 | DTC Client socket (2) | Connecting to IP: 69.39.70.245. 2025-06-26 17:33:09.018 | Delayed Data Feed | Connecting to the server ds32.sierracharts.com. Port 10043 2025-06-26 17:33:09.019 | DTC Client socket (3) | Creating socket. 2025-06-26 17:33:09.019 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:33:09.019 | DTC Client socket (3) | Connecting to IP: 69.39.70.248. 2025-06-26 17:33:09.084 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:33:09.084 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:33:09.084 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:33:09.299 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:33:09.299 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:33:09.299 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:33:09.299 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:33:09.299 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:33:09.299 | DTC Client socket (2) | Closed. 2025-06-26 17:33:09.300 | Delayed Data Feed | Failed connections: 20 2025-06-26 17:33:09.300 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:33:09.300 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:33:09.300 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:33:09.370 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:33:09.370 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:33:09.371 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:33:09.537 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:33:09.537 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:33:09.537 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:33:09.537 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:33:09.538 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:33:09.538 | DTC Client socket (3) | Closed. 2025-06-26 17:33:09.538 | Delayed Data Feed | Failed connections: 36 2025-06-26 17:33:09.538 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:33:09.538 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:33:09.538 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:33:14.300 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2025-06-26 17:33:14.300 | DTC Client socket (2) | Creating socket. 2025-06-26 17:33:14.300 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:33:14.300 | DTC Client socket (2) | Connecting to IP: 67.214.125.11. 2025-06-26 17:33:14.534 | Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 2025-06-26 17:33:14.534 | DTC Client socket (3) | Creating socket. 2025-06-26 17:33:14.534 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:33:14.535 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2025-06-26 17:33:17.755 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:33:17.755 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:33:17.756 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:33:21.514 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:33:21.514 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:33:21.514 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:33:29.627 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:33:29.627 | DTC Client socket (1) | Write has completed. Shutdown being performed. 2025-06-26 17:33:29.627 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:33:29.627 | DTC Client socket (1) | Closed. 2025-06-26 17:33:36.471 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:33:36.471 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:33:36.471 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:33:36.471 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:33:36.471 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:33:36.471 | DTC Client socket (3) | Closed. 2025-06-26 17:33:36.471 | Delayed Data Feed | Failed connections: 37 2025-06-26 17:33:36.471 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:33:36.471 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:33:36.471 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:33:40.509 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:33:40.509 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:33:40.509 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:33:40.509 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:33:40.509 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:33:40.509 | DTC Client socket (2) | Closed. 2025-06-26 17:33:40.509 | Delayed Data Feed | Failed connections: 21 2025-06-26 17:33:40.509 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:33:40.509 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:33:40.509 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:33:41.470 | Delayed Data Feed | Connecting to the server ds25.sierracharts.com. Port 10043 2025-06-26 17:33:41.471 | DTC Client socket (1) | Creating socket. 2025-06-26 17:33:41.471 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:33:41.471 | DTC Client socket (1) | Connecting to IP: 64.152.155.20. 2025-06-26 17:33:42.530 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:33:42.530 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:33:42.530 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:33:45.501 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-06-26 17:33:45.502 | DTC Client socket (2) | Creating socket. 2025-06-26 17:33:45.502 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:33:45.502 | DTC Client socket (2) | Connecting to IP: 64.152.155.116. 2025-06-26 17:33:45.779 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:33:45.779 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:33:45.779 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:34:01.218 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:34:01.218 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:34:01.218 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:34:01.218 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:34:01.218 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:34:01.218 | DTC Client socket (1) | Closed. 2025-06-26 17:34:01.218 | Delayed Data Feed | Failed connections: 38 2025-06-26 17:34:01.218 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:34:01.218 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:34:01.219 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:34:04.338 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:34:04.338 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:34:04.338 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:34:04.338 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:34:04.338 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:34:04.338 | DTC Client socket (2) | Closed. 2025-06-26 17:34:04.338 | Delayed Data Feed | Failed connections: 22 2025-06-26 17:34:04.338 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:34:04.338 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:34:04.338 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:34:06.212 | Delayed Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 10043 2025-06-26 17:34:06.216 | DTC Client socket (2) | Creating socket. 2025-06-26 17:34:06.216 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:34:06.216 | DTC Client socket (2) | Connecting to IP: 64.152.155.21. 2025-06-26 17:34:06.578 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:34:06.578 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:34:06.578 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:34:09.327 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2025-06-26 17:34:09.327 | DTC Client socket (1) | Creating socket. 2025-06-26 17:34:09.327 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:34:09.327 | DTC Client socket (1) | Connecting to IP: 69.39.70.245. 2025-06-26 17:34:09.778 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:34:09.778 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:34:09.779 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:34:25.170 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:34:25.170 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:34:25.170 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:34:25.170 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:34:25.171 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:34:25.171 | DTC Client socket (2) | Closed. 2025-06-26 17:34:25.171 | Delayed Data Feed | Failed connections: 39 2025-06-26 17:34:25.171 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:34:25.171 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:34:25.171 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:34:28.258 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:34:28.258 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:34:28.258 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:34:28.258 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:34:28.259 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:34:28.259 | Delayed Data Feed | Failed connections: 23 2025-06-26 17:34:28.259 | DTC Client socket (1) | Closed. 2025-06-26 17:34:28.259 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:34:28.259 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:34:28.259 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:34:30.165 | Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 2025-06-26 17:34:30.165 | DTC Client socket (1) | Creating socket. 2025-06-26 17:34:30.165 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:34:30.165 | DTC Client socket (1) | Connecting to IP: 67.214.125.5. 2025-06-26 17:34:30.378 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:34:30.378 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:34:30.378 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:34:33.258 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2025-06-26 17:34:33.259 | DTC Client socket (2) | Creating socket. 2025-06-26 17:34:33.259 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:34:33.259 | DTC Client socket (2) | Connecting to IP: 67.214.125.11. 2025-06-26 17:34:33.659 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:34:33.659 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:34:33.659 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:34:48.631 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:34:48.631 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:34:48.631 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:34:48.631 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:34:48.631 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:34:48.631 | DTC Client socket (1) | Closed. 2025-06-26 17:34:48.631 | Delayed Data Feed | Failed connections: 40 2025-06-26 17:34:48.631 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:34:48.631 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:34:48.631 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:34:53.622 | Delayed Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10043 2025-06-26 17:34:53.622 | DTC Client socket (1) | Creating socket. 2025-06-26 17:34:53.622 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:34:53.622 | DTC Client socket (1) | Connecting to IP: 69.39.70.249. 2025-06-26 17:34:53.637 | Delayed Data Feed | Did not receive Encoding Response from server. Disconnecting. * 2025-06-26 17:34:53.637 | Delayed Data Feed | Waiting for socket receive thread to end 2025-06-26 17:34:53.638 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:34:53.638 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:34:53.638 | DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2025-06-26 17:34:53.638 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:34:53.761 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:34:53.761 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:34:53.761 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:34:58.641 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-06-26 17:34:58.641 | DTC Client socket (3) | Creating socket. 2025-06-26 17:34:58.641 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:34:58.641 | DTC Client socket (3) | Connecting to IP: 64.152.155.116. 2025-06-26 17:34:58.819 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:34:58.819 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:34:58.819 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:35:11.540 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:35:11.540 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:35:11.540 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:35:11.540 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:35:11.540 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:35:11.540 | DTC Client socket (1) | Closed. 2025-06-26 17:35:11.540 | Delayed Data Feed | Failed connections: 41 2025-06-26 17:35:11.540 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:35:11.540 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:35:11.540 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:35:16.539 | Delayed Data Feed | Connecting to the server ds32.sierracharts.com. Port 10043 2025-06-26 17:35:16.539 | DTC Client socket (1) | Creating socket. 2025-06-26 17:35:16.539 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:35:16.539 | DTC Client socket (1) | Connecting to IP: 69.39.70.248. 2025-06-26 17:35:16.989 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:35:16.989 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:35:16.989 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:35:17.399 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:35:17.399 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:35:17.399 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:35:17.399 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:35:17.400 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:35:17.400 | DTC Client socket (3) | Closed. 2025-06-26 17:35:17.400 | Delayed Data Feed | Failed connections: 24 2025-06-26 17:35:17.400 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:35:17.400 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:35:17.400 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:35:22.393 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2025-06-26 17:35:22.399 | DTC Client socket (3) | Creating socket. 2025-06-26 17:35:22.399 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:35:22.399 | DTC Client socket (3) | Connecting to IP: 69.39.70.245. 2025-06-26 17:35:22.623 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:35:22.623 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:35:22.623 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:35:36.970 | Delayed Data Feed | Did not receive Encoding Response from server. Disconnecting. * 2025-06-26 17:35:36.970 | Delayed Data Feed | Waiting for socket receive thread to end 2025-06-26 17:35:36.970 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:35:36.970 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:35:36.970 | DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2025-06-26 17:35:36.970 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:35:41.603 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:35:41.603 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:35:41.603 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:35:41.603 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:35:41.603 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:35:41.603 | DTC Client socket (3) | Closed. 2025-06-26 17:35:41.603 | Delayed Data Feed | Failed connections: 25 2025-06-26 17:35:41.603 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:35:41.603 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:35:41.603 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:35:41.974 | Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 2025-06-26 17:35:41.975 | DTC Client socket (3) | Creating socket. 2025-06-26 17:35:41.975 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:35:41.975 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2025-06-26 17:35:42.088 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:35:42.088 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:35:42.088 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:35:46.599 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2025-06-26 17:35:46.600 | DTC Client socket (4) | Creating socket. 2025-06-26 17:35:46.600 | DTC Client socket (4) | New receive buffer size: 0 2025-06-26 17:35:46.600 | DTC Client socket (4) | Connecting to IP: 67.214.125.11. 2025-06-26 17:35:46.704 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:35:46.705 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:35:46.705 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:35:48.027 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:35:48.027 | DTC Client socket (2) | Write has completed. Shutdown being performed. 2025-06-26 17:35:48.027 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:35:48.027 | DTC Client socket (2) | Closed. 2025-06-26 17:36:00.380 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:36:00.380 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:36:00.380 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:36:00.380 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:36:00.380 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:36:00.380 | DTC Client socket (3) | Closed. 2025-06-26 17:36:00.380 | Delayed Data Feed | Failed connections: 42 2025-06-26 17:36:00.381 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:36:00.381 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:36:00.381 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:36:04.993 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:36:04.993 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-06-26 17:36:04.993 | DTC Client socket (4) | CloseSocket call. 2025-06-26 17:36:04.993 | DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:36:04.993 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:36:04.993 | DTC Client socket (4) | Closed. 2025-06-26 17:36:04.993 | Delayed Data Feed | Failed connections: 26 2025-06-26 17:36:04.993 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:36:04.993 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:36:04.993 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:36:05.380 | Delayed Data Feed | Connecting to the server ds25.sierracharts.com. Port 10043 2025-06-26 17:36:05.381 | DTC Client socket (2) | Creating socket. 2025-06-26 17:36:05.381 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:36:05.381 | DTC Client socket (2) | Connecting to IP: 64.152.155.20. 2025-06-26 17:36:05.614 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:36:05.614 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:36:05.614 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:36:09.988 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-06-26 17:36:09.988 | DTC Client socket (3) | Creating socket. 2025-06-26 17:36:09.988 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:36:09.988 | DTC Client socket (3) | Connecting to IP: 64.152.155.116. 2025-06-26 17:36:10.205 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:36:10.205 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:36:10.205 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:36:23.951 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:36:23.951 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:36:23.951 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:36:23.951 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:36:23.952 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:36:23.952 | DTC Client socket (2) | Closed. 2025-06-26 17:36:23.952 | Delayed Data Feed | Failed connections: 43 2025-06-26 17:36:23.952 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:36:23.952 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:36:23.952 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:36:28.650 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:36:28.650 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-06-26 17:36:28.650 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:36:28.650 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:36:28.650 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:36:28.650 | DTC Client socket (3) | Closed. 2025-06-26 17:36:28.650 | Delayed Data Feed | Failed connections: 27 2025-06-26 17:36:28.650 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:36:28.650 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:36:28.650 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:36:28.956 | Delayed Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 10043 2025-06-26 17:36:28.957 | DTC Client socket (2) | Creating socket. 2025-06-26 17:36:28.957 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:36:28.957 | DTC Client socket (2) | Connecting to IP: 64.152.155.21. 2025-06-26 17:36:29.281 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:36:29.281 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:36:29.281 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:36:33.646 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2025-06-26 17:36:33.647 | DTC Client socket (3) | Creating socket. 2025-06-26 17:36:33.647 | DTC Client socket (3) | New receive buffer size: 0 2025-06-26 17:36:33.647 | DTC Client socket (3) | Connecting to IP: 69.39.70.245. 2025-06-26 17:36:34.192 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:36:34.192 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:36:34.192 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:36:40.220 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:36:40.220 | DTC Client socket (1) | Write has completed. Shutdown being performed. 2025-06-26 17:36:40.220 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:36:40.220 | DTC Client socket (1) | Closed. 2025-06-26 17:36:48.020 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:36:48.020 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:36:48.020 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:36:48.020 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:36:48.020 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:36:48.020 | DTC Client socket (2) | Closed. 2025-06-26 17:36:48.020 | Delayed Data Feed | Failed connections: 44 2025-06-26 17:36:48.020 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:36:48.020 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:36:48.020 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:36:53.001 | Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 2025-06-26 17:36:53.002 | DTC Client socket (1) | Creating socket. 2025-06-26 17:36:53.002 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:36:53.002 | DTC Client socket (1) | Connecting to IP: 67.214.125.5. 2025-06-26 17:36:53.246 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:36:53.246 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:36:53.246 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:36:54.179 | Delayed Data Feed | Did not receive Encoding Response from server. Disconnecting. * 2025-06-26 17:36:54.179 | Delayed Data Feed | Waiting for socket receive thread to end 2025-06-26 17:36:54.179 | DTC Client socket (3) | CloseSocket call. 2025-06-26 17:36:54.179 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:36:54.179 | DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 2025-06-26 17:36:54.179 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:36:59.174 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043 2025-06-26 17:36:59.174 | DTC Client socket (2) | Creating socket. 2025-06-26 17:36:59.174 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:36:59.174 | DTC Client socket (2) | Connecting to IP: 67.214.125.11. 2025-06-26 17:36:59.482 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:36:59.482 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:36:59.482 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:37:10.429 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:37:10.429 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:37:10.429 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:37:10.429 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:37:10.430 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:37:10.430 | DTC Client socket (1) | Closed. 2025-06-26 17:37:10.430 | Delayed Data Feed | Failed connections: 45 2025-06-26 17:37:10.430 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:37:10.430 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:37:10.430 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:37:15.431 | Delayed Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10043 2025-06-26 17:37:15.432 | DTC Client socket (1) | Creating socket. 2025-06-26 17:37:15.432 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:37:15.432 | DTC Client socket (1) | Connecting to IP: 69.39.70.249. 2025-06-26 17:37:15.621 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:37:15.621 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:37:15.621 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:37:17.620 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:37:17.620 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:37:17.620 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:37:17.620 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:37:17.620 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:37:17.620 | DTC Client socket (2) | Closed. 2025-06-26 17:37:17.620 | Delayed Data Feed | Failed connections: 28 2025-06-26 17:37:17.620 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:37:17.621 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:37:17.621 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:37:22.620 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-06-26 17:37:22.620 | DTC Client socket (2) | Creating socket. 2025-06-26 17:37:22.620 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:37:22.620 | DTC Client socket (2) | Connecting to IP: 64.152.155.116. 2025-06-26 17:37:22.781 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:37:22.781 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:37:22.781 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:37:34.021 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:37:34.021 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:37:34.021 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:37:34.021 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:37:34.021 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:37:34.021 | DTC Client socket (1) | Closed. 2025-06-26 17:37:34.021 | Delayed Data Feed | Failed connections: 46 2025-06-26 17:37:34.021 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:37:34.021 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:37:34.021 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:37:39.018 | Delayed Data Feed | Connecting to the server ds32.sierracharts.com. Port 10043 2025-06-26 17:37:39.018 | DTC Client socket (1) | Creating socket. 2025-06-26 17:37:39.019 | DTC Client socket (1) | New receive buffer size: 0 2025-06-26 17:37:39.019 | DTC Client socket (1) | Connecting to IP: 69.39.70.248. 2025-06-26 17:37:39.157 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:37:39.157 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:37:39.157 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:37:42.021 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:37:42.021 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-06-26 17:37:42.021 | DTC Client socket (2) | CloseSocket call. 2025-06-26 17:37:42.021 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:37:42.021 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:37:42.021 | DTC Client socket (2) | Closed. 2025-06-26 17:37:42.021 | Delayed Data Feed | Failed connections: 29 2025-06-26 17:37:42.021 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:37:42.021 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:37:42.021 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2025-06-26 17:37:47.018 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2025-06-26 17:37:47.019 | DTC Client socket (2) | Creating socket. 2025-06-26 17:37:47.019 | DTC Client socket (2) | New receive buffer size: 0 2025-06-26 17:37:47.019 | DTC Client socket (2) | Connecting to IP: 69.39.70.245. 2025-06-26 17:37:47.158 | Delayed Data Feed | Network connection to server complete. 2025-06-26 17:37:47.158 | Delayed Data Feed | Starting socket receive thread. 2025-06-26 17:37:47.158 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-06-26 17:37:57.674 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-06-26 17:37:57.674 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-06-26 17:37:57.675 | DTC Client socket (1) | CloseSocket call. 2025-06-26 17:37:57.675 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-06-26 17:37:57.675 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-06-26 17:37:57.675 | DTC Client socket (1) | Closed. 2025-06-26 17:37:57.675 | Delayed Data Feed | Failed connections: 47 2025-06-26 17:37:57.675 | DTC Client socket (0) | CloseSocket call. 2025-06-26 17:37:57.675 | Delayed Data Feed | Disconnected from the server. 2025-06-26 17:37:57.675 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. |
| [2025-06-26 18:13:14] |
| John - SC Support - Posts: 48555 |
You are getting the following error in your log: Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
Refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
