Date/Time: Wed, 25 Nov 2026 20:51:43 +0000
Monthly chart - 2 background
View Count: 425
| [2025-06-26 16:45:29] |
| smoothoperator - Posts: 5 |
Dear SC - hope the team is doing well. Sorry if this question has been covered before - not sure why the monthly chart (see attached) has 2 background colors? I am certain my full session has been turned off and my chart data type is Intraday Chart only (see chart setting attached). Conversely, this 2 background color seems to only happen for monthly time frame; for quarterly, weekly, daily, etc, the background is one background color. I just want to make sure bc I want to make sure the data (which I use to chart) is not using globex data. Thank you very much in advance. |
Private File Private File Private File |
| [2025-06-26 17:05:43] |
| John - SC Support - Posts: 48658 |
You have a "Time Range Highlight" study on your chart that is set to color from 16:15:00 to 09:29:59. We assume this is the reason for the coloring. On the one chart that shows a different color in the forward projection area, you probably have the Input for "Display in Forward Projection Area" for that study set to "Yes". And you probably have it set to "No" in the other charts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
