Date/Time: Thu, 26 Nov 2026 03:53:22 +0000
Request: Draw Style
View Count: 746
[2025-06-25 00:30:11]
HumblyTrading - Posts: 226
Hello SC Team,
I hope 2025 is going very well!
There is a Draw Style "Background - All Regions" which is very handy, but would be more useful if we could apply the transparency options to it.
Thank you for your consideration,
Mike
[2025-06-27 07:27:34]
Tony - Posts: 738
You probably already know, just in case:
there is also a Subgraph pair:
Transparent Fill Top and Transparent Fill Bottom,
works really well for me.
[2025-07-01 04:20:01]
Yes. This request is about a transparent background across all regions, as only a nontransparent option currently exists.
[2025-07-01 17:32:39]
ForgivingComputers.com - Posts: 1256
Am I missing something?
If it is the background, what could be behind it that you would need the background to be transparent?
[2025-07-02 14:43:36]
It allows for certain visual effects, where you can just barely see the background, so that it is not overwhelming on busy charts…
This feature exists as a transparent background for a single region. What I tend to do, is just duplicate that particular study into the other regions.
It would reduce the number of times I have to do that if this feature were added…
It is not mission critical, but would be nice to have.
[2026-02-24 19:04:25]
Sierra_Chart Engineering - Posts: 25489
We will look this over.
[2026-03-28 02:25:53]
This has been added:
