Date/Time: Wed, 25 Nov 2026 20:51:42 +0000
FVX
View Count: 550
[2025-06-24 21:04:44]
User841161 - Posts: 357
FVX is the CBOE 5 Year Treasury Yield, when charting in comes up with yield on y axis as 38.56, is there a way to correct that globally to fix it to the correct yield as 3.856 or 3.856%.
image6-24-25-1.JPG / V - Attached On 2025-06-24 21:04:34 UTC - Size: 105.44 KB - 279 views
[2025-06-24 21:19:45]
John - SC Support - Posts: 48658
The value of 38.56 is the correct value from the exchange. Refer to the following:
https://www.cboe.com/us/indices/dashboard/FVX/
If you want to change how you view it, then you can adjust the "Real-Time Price Multiplier" and the "Historical Price Multiplier" (and other necessary settings if you do change these as called out in the documentation). Refer to the following and the item below it:
Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
