Date/Time: Wed, 25 Nov 2026 20:51:41 +0000
Button to extend a target order
View Count: 546
| [2025-06-24 14:52:53] |
| AntoineOpala - Posts: 91 |
I am using preset share quantities with attached orders to enter positions with a fixed risk unit. Once a position is entered, I find myself manually clicking the DOM to extend my target or tighten it, depending on how markets evolve. Question: is it possible to build a button (for example sitting on a control bar) that would instantly x2 the current target? x1.5, x0.5 and so forth... If so, how? I have tinkered with the study called "Trade Management by Study" to no avail. This is for scalping, in situations where time to scroll the DOM, mentally calculate where a x2 target would be then click that price, is limited. |
| [2025-06-24 16:03:18] |
| John - SC Support - Posts: 48658 |
There is not a built-in way to do this. There are trading control bar buttons for moving a Target/Stop up or down 1 tick at a time, but not X2 the current distance from the parent order. To do this, you would need to create a custom study in which you can have a control bar button to have it do what you want. Refer to the following: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events Automated Trading From an Advanced Custom Study https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
