Date/Time: Wed, 25 Nov 2026 20:51:43 +0000
DOM question
View Count: 438
| [2025-06-24 06:09:59] |
| User781731 - Posts: 74 |
I have these chart settings on my DOM: Symbol: ES Trade and current Quote Symbol: MES Use as Trade Only Symbol: Yes Can you confirm this means the data on the DOM will be ES and not MES? The reason I have the settings as ES/MES on the DOM is because this is my setting on the main chart window and I want the orders/position lines from the main chart window to be visible on the DOM. But I want the DOM to show the data for ES. I am not executing trades on the DOM itself. |
| [2025-06-24 15:47:43] |
| John - SC Support - Posts: 48658 |
With these settings, the data will be for the ES. If you actually make a trade with these settings, then the trade will be for the MES.
