Date/Time: Wed, 25 Nov 2026 20:51:43 +0000
Free trial data feed
View Count: 4693
| [2025-06-23 14:07:44] |
| Oradno - Posts: 2 |
Hello Sierra Chart Support, I am currently using the Free Trial of Sierra Chart and would like to request the 10-day real-time CME futures data trial (Denali Data Feed), for symbols like MES, ES, NQ, etc. Thank you! |
| [2025-06-23 14:23:02] |
| SC Support - Posts: 2116 |
Not possible Oradno, you would need to be on a Paid Sierra Chart Package one of SP10, SP11 or SP12 in order to take advantage of the CME's calendar month Real-time Data Trial. Description of Service Packages and Pricing: Packages Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Account Control Panel" on the Sierra Chart software menu. On the displayed webpage, click on "Activate Services". Or you can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password if necessary. 2. Choose the particular Service Package and the number of Months that you want and press the "Update/Set" button. If you are on a Trial, you will first need to add sufficient credit to your account to pay for the chosen Service Package/Months. In this case, refer to the step below. Once that is done you can then choose the Service Package and number of Months. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access |
