Date/Time: Wed, 25 Nov 2026 21:05:56 +0000
TPO Value Area Lines SHow incorrect levels
View Count: 496
| [2025-06-23 10:34:28] |
| 3698963 - Posts: 11 |
Dear Team, On a chart with session times divided into RTH and Evening, I imported the TPO-Value Area Lines indicator with a reference of 1 Day Back, set only for the Day Session. However, the levels it displays are incorrect. Meanwhile, the same indicator applied to the Volume Profile levels, with the same settings, works correctly. I’m attaching some example images to show the issue. Thanks Date Time Of Last Edit: 2025-06-23 10:54:16
| [2025-06-23 12:46:15] |
| Sierra_Chart Engineering - Posts: 25483 |
Refer to: Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
