Date/Time: Wed, 25 Nov 2026 21:06:03 +0000
Point and figure chart
View Count: 502
| [2025-06-20 19:21:11] |
| Tradingfutures_NQ - Posts: 3 |
Hi i was trying to configure my footprint chart based on point and figure but im struggling with that because i dont fnd where can i change that. Could you help me? Thanks H. |
| [2025-06-20 19:27:52] |
| John - SC Support - Posts: 48659 |
Set "Chart >> Chart Settings >> Bar Period >> Bar Period Type" to "Point and Figure Bar". Then set the "Box Size" and "Reversal Size" in the field just below it after you select the Point and Figure. Refer to the following: Chart Settings: Point and Figure Bar (Intraday Charts) (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings >> Bar Period) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
