Date/Time: Wed, 25 Nov 2026 21:05:57 +0000
closed numbers bar candles constantly changing data on columns
View Count: 545
| [2025-06-20 05:32:11] |
| User610117 - Posts: 47 |
I have a range chart with a numbers bar study. Something triggers the chart to constantly change column data (volume/delta) on closed bars. I currently have the settings as interactive scale range, scale range: constant range. Can I get some help to solve this mystery? Thank you! |
| Attachment Deleted. |
| [2025-06-20 14:46:33] |
| John - SC Support - Posts: 48659 |
Please get us that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-20 15:37:04] |
thank you for looking into this for me. attached is the single chart .cht
| [2025-06-20 15:56:12] |
What you are seeing is due to how small you have the Numbers Bars data, along with how dense the data itself is, and also with the scale set to re-center to the last bar on every update. Therefore, as the chart shifts up/down the particular bars that can be seen/drawn are changing. This is strictly a drawing issue, the data itself is not changing. If you want to keep this size for the bars, then we recommend changing the "Volume at Price Multiplier" for the chart. Setting it to a value of 2 may be enough to take care of this for you. Otherwise, you would need to make the bars larger in order to overcome this display issue. Refer to the following: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-20 16:20:00] |
that was a great improvement, thank you so much!
