Date/Time: Wed, 25 Nov 2026 21:05:59 +0000
Disabled Double-Click Scale Re-Centre
View Count: 529
| [2025-06-19 13:37:23] |
| User753526 - Posts: 87 |
Is it possible to disable the automatic recentering of the price scale when you double-click? I have changed 3 mouses but quick often when I move the price range scale, the chart rescales as though I have double clicked.
| [2025-06-19 16:44:39] |
| John - SC Support - Posts: 48659 |
There is not a way to disable this in Sierra Chart. The only suggestion we can make is to decrease the double-click time in your Operating System in order for the system to not interpret what is a mistaken double-click instead of an intentional one. This does mean that you have to be faster in your intentional double clicks, however, so you may need to find the best tradeoff for what you want.
