Date/Time: Wed, 25 Nov 2026 21:06:01 +0000
Obtaining a different replay date
View Count: 582
| [2025-06-19 00:16:20] |
| cmack1011 - Posts: 201 |
I am attempting to replay today's trading data (6/18/25) starting at 6:00 am CST. However, the chart always starts the replay on May 19, 2025? I have checked the time zone setting in the chart which is correct. Please advise. Thx |
| [2025-06-19 14:09:01] |
| John - SC Support - Posts: 48659 |
If you are trying to start the replay using the "Use Start Date-Time" option, then our guess is that you have a typo in your date entry, such that it is from before a point at which you have data in your chart. Therefore, the replay will start at the first date for which you do have data. Please double-check this entry to ensure the date is correctly entered (it should be in the format YYYY-MM-DD, where YYYY is the 4 digit year, MM is the 2 digit month, and DD is the two digit day). One way to start the replay to avoid this is to not use the "Use Start Date-Time" option and instead scroll the chart back to where you want the replay to begin. The last displayed bar to the right in the chart will be where the replay starts. Refer to the following: Replaying Charts: Basic Chart Replay Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-19 14:13:40] |
| ForgivingComputers.com - Posts: 1256 |
Also make sure you check the box "Use Start Date-Time". |
