Date/Time: Wed, 25 Nov 2026 21:06:16 +0000
DOM setup....
View Count: 508
[2025-06-17 13:58:32]
User355500 - Posts: 2
Subject updated from 'Denali Data Feed' to 'DOM setup....'
Hello, How do I change the BUY and SELL columns to app green for buy and red for sell.... I'm following me mentor and his are green and red.
thank you...see screenshots
image6-16-2025 3-49-55 PM.png / V - Attached On 2025-06-17 13:58:24 UTC - Size: 17.72 KB - 286 views
image6-16-2025 3-51-54 PM.png / V - Attached On 2025-06-17 13:58:28 UTC - Size: 83.28 KB - 280 views
[2025-06-17 14:00:19]
John - SC Support - Posts: 48659
To change the background color, refer to the following:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Buy Column Background
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Bid Column Background
For the text, refer to the following:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Ask Depth Quantities
[2025-06-17 15:36:30]
Hello, trying to change DOM setup colors... all the links say something must be "ENABLED". what/where do I find "enabled" Thank You
[2025-06-17 15:57:11]
Go to the specific graphics setting you want to change on the Graphics Settings window. If that item needs to be "Enabled" then there will be a checkbox next to the word "Enable" that you can select. If the Enable option is grayed out then it does not need to be enabled, as it is always enabled.
