Date/Time: Wed, 25 Nov 2026 21:06:11 +0000
Market Depth Historical Show Last Quantity not showing
View Count: 624
[2025-06-16 19:13:22]
TopGunTrader - Posts: 313
I'm using Market Depth Historical Graph and when I slide it further to the RIGHT next to the price column the numbers disappear. How can I fix this I don't want to waste an inch of space on charts.
Capture2 is original and Capture pic shows the numbers gone when I move it over.
imageCapture2.PNG / V - Attached On 2025-06-16 19:13:11 UTC - Size: 78.74 KB - 239 views
imageCapture.PNG / V - Attached On 2025-06-16 19:13:15 UTC - Size: 86.17 KB - 231 views
[2025-06-17 14:47:15]
John - SC Support - Posts: 48659
What is the Input for "Show Quantity Numbers" set to?
[2025-06-19 11:36:00]
Show Quantity Numbers is set to Only After Last Bar
[2025-06-19 16:20:55]
What you are seeing is correct. Since you are only displaying the quantities "after the last bar" then as you scroll the chart such that the last bar is now at the far right side, those values will not be displayed, as there is no place to display them. You would need to keep the last bar a bar (or two) to the left in order to be able to view that specific data.
[2025-06-19 20:53:03]
That makes sense however there is a LOT of empty black space. I understand if I move it over too far the numbers go away but they disappear at least an inch from the side and thus conserving space on smaller charts this is a tremendous waste. I thought maybe I have some setting messed up but after a certain point numbers are just gone but there's tons of room with black space before the right price column.
[2025-06-19 21:09:43]
We wonder if you have the "Percentage of Fill Space to Display Market Depth Quantity Rectangles In" set to a number other than 100. Please try 100 and let us know if this does not resolve it.
