Date/Time: Wed, 25 Nov 2026 21:06:04 +0000
Region dividing line partially blocked by fill from study above
View Count: 519
| [2025-06-16 12:43:00] |
| User548831 - Posts: 6 |
Hello, Is it possible to have the Region Dividing Line always on top of the studies from Region 1? How studies are on top of the line as you can see in the attached screenshot. Edit: So on the chart I have enabled: "Interactive Scale Range" and "Scale Range: Automatic" On the studies: "Same as Region": I do this so that SC doesn't keep all the indicators in view, I only want all the candle sticks in view. So the studies are drawn over the white Region Dividing Line. It's not that noticeable For studies that only produce a line, but for studies that fill top/bottom between lines (like VWAP stdev), they make the white line disappear as shown in the screenshot. Date Time Of Last Edit: 2025-06-17 05:21:21
| [2025-06-17 06:30:41] |
So basically I'd like the following behavior: The scale padding percentage is set to 2% so that the candle sticks have a margin top and bottom. This works great. The studies that are set to "Same as Region" but have 0% padding, so they touch the Region Dividing Line, and are drawn over it, so on those sections the line disappears. I'd like the studies to remain on "Same as Region", but also have some padding so the region dividing line is always visible. |
