Date/Time: Wed, 25 Nov 2026 21:06:01 +0000
Volume Profile Help
View Count: 605
| [2025-06-16 12:27:53] |
| GravisHTG - Posts: 321 |
I wonder if we can have the Volume profile of : One period at the end of fixed time , but for a back reference ( would like to see the last Full development ) I try to input in Number of perdiod back to reference - did not allow other than 0 I try A start date End date - did not work. Anything I am missing here ? thanks |
| [2025-06-16 16:09:43] |
| John - SC Support - Posts: 48659 |
Refer to the first paragraph here for why this does not work: Volume By Price Study: Number Of Periods Back To Reference The only current solution for this would be to use a period type of "From Start Date-Time + Fixed Time Length". You would need to update the date of this profile each day. Refer to the following: Volume By Price Study: From Start Date-Time + Fixed Time Length For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
