Date/Time: Wed, 25 Nov 2026 21:06:04 +0000
Cannot Delete Order format in Trade Window
View Count: 464
| [2025-06-16 05:47:01] |
| bobstone249 - Posts: 61 |
I have an order format in the Trade Window which will not leave the options list no matter what I do. I've renamed it - it duplicates the file and now I can't delete either of them. Any ideas? Thanks |
| [2025-06-16 12:50:40] |
| Sierra_Chart Engineering - Posts: 25483 |
Are you referring to a Trade Window Configuration? Here are the instructions to delete it: Basic Trading and the Trade Window: Delete Configuration File Check the Window >> Message Log for any error messages relating to deleting it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-06-16 12:50:58
