Date/Time: Wed, 25 Nov 2026 21:06:07 +0000
SC compatibility with Lime.co?
View Count: 485
| [2025-06-13 19:20:36] |
| User634299 - Posts: 2 |
Hi. It seems that Lime.co supports API connections using the FIX protocol and DTC. Does SierraChart support connections with this broker? thks |
| [2025-06-13 19:46:02] |
| John - SC Support - Posts: 48659 |
Apart from the existing connections, we will not work with a broker through FIX or any specialized API. We will only do so if they implement the DTC Protocol. We do not see anything on Lime.co's website about supporting the DTC Protocol.
