Date/Time: Wed, 25 Nov 2026 07:56:01 +0000
Feature Request - Daily OHLC-Single Point Study
View Count: 600
| [2025-06-13 17:15:01] |
| User82146 - Posts: 15 |
Hello, For the Daily OHLC-Single Point, can you all consider adding individual extension line properties for Open, High, Low, and Close separately? Or tie the extension line draw style to the draw style of the line being extended (if high is hidden, hide the extension? Thanks! |
| [2025-06-13 18:21:20] |
| John - SC Support - Posts: 48648 |
We have taken this as a Feature Request. We take all requests, but we can not say when we would get to any particular item.
| [2025-09-09 15:19:20] |
| Sierra_Chart Engineering - Posts: 25479 |
Do not wait for us on this. Simply do this yourself: How to Build an Advanced Custom Study from Source Code You can get the source code of the study and modify it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-09 15:20:45
