Date/Time: Wed, 25 Nov 2026 21:05:55 +0000
How do I get 1ms Chart Update Interval...
View Count: 1326
[2025-06-13 16:17:47]
iAmTheFuture - Posts: 11
I need the fastest update speeds for the chart and my ACSIL studies how do I do it 10 is to much I need 1ms or less. There has to be a way!
[2025-06-13 17:00:03]
blt - Posts: 233
sorry to intrude at this-just wondering what could be the need behind your inquiry
you must be automated/algo trader and even then you must be having DA to CME (although I doubt it)
if your PING is less than 1ms I could try to understand it
still it is very confusing to me why such a low value
if it's not too much to ask I would appreciate your insight into matter
thank you
p.s. my PING is 7 ms
[2025-06-13 17:33:59]
Tony - Posts: 738
in the future, the ping will be 7ns, he is the future
[2025-06-13 18:25:15]
John - SC Support - Posts: 48659
The lowest setting for the "Chart Update Interval" is 10 milliseconds. It can not be set any lower than this at this time.
Whether this will ever change we can not say. If there is enough of a need eventually, then it would be something we would look into. At this time, there is simply not the requirement for this.
