Date/Time: Wed, 25 Nov 2026 21:06:03 +0000
Study Subgraphs Reference appears NOT to work
View Count: 590
| [2025-06-13 12:19:09] |
| TopGunTrader - Posts: 313 |
Hi, I created range stats for each bar and id7.sg1 is the open plus blue line, id8.sg1 is open + 0.8*avg range they show as green and gray. When using the study subgraphs as I want this to show filled colors for these two lines they are wrong on 80-90% of the bars. I've attached chart and pic. |
| [2025-06-13 12:28:42] |
| User431178 - Posts: 910 |
You need to set Study Subgraphs Reference scale range mode to Same as Region or Automatic, default is Independent (which the image suggests it is set to now).
| [2025-06-13 12:42:46] |
NEVER MIND my other instance had different settings than main chart independent does not work when put on same as chart for scaling now works. Leaving post in hopes it helps others and saves you guys having to respond.
| [2025-06-13 12:57:11] |
| Sawtooth - Posts: 4362 |
IMO, the default Scale Range should not be Independent.
