Date/Time: Wed, 25 Nov 2026 21:06:04 +0000
[User Discussion] - E-Mini Vs Micro Indices Volumes
View Count: 983
| [2025-06-12 21:00:28] |
| User350195 - Posts: 37 |
Hello, why do E-Mini and Micros Volume by Price differ so much in the same Continues Contract configuration? Is there any way to align them to be the same?
| [2025-06-12 21:19:03] |
| John - SC Support - Posts: 48659 |
Each of these is a distinct product, so each is traded differently, resulting in different data. So if you are asking why your Volume by Price profiles are different, this is why. If you are asking something else, then we are not understanding the specific question. Please give us more information on what you are wanting to do or see. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-12 22:59:34] |
I am comparing E-Mini ES and Micro ES volumes by price and they differ drastically. Is there any way to align them to match exactly? Thanks! |
| [2025-06-13 16:42:57] |
| Tony - Posts: 738 |
@User350195 I compared VbPs for ES and MES, they are not 100% identical, but fairly close, I am trading MES but I never load MES chart, I always trade MES on a ES chart, attached a screenshot of settings |
