Date/Time: Wed, 25 Nov 2026 21:05:59 +0000
[Programming Help] - Use Attached Order via ACSIL
View Count: 733
| [2025-06-12 14:37:04] |
| User48838 - Posts: 134 |
Is it possible to turn on Use Attached Order on the DOM using ACSIL? I want to turn it on when position is =0 and turn it off if position <> 0
| [2025-06-12 18:02:16] |
| ForgivingComputers.com - Posts: 1256 |
Not directly, but you can save two TWConfig files, one with Use Attached Order Checked, and one without. Or you could have one config file without brackets. You can then set the TWConfig file with sc.TradeWindowConfigFileName = "No_Attached.twconfig";
Date Time Of Last Edit: 2025-06-12 18:04:32
| [2025-06-13 02:17:08] |
TY, I got this to work with Claude's help.
Date Time Of Last Edit: 2025-06-13 02:18:07
