Date/Time: Wed, 25 Nov 2026 21:06:02 +0000
2 separate interactive brokers accounts viewable in one sierra chart sign on?
View Count: 525
| [2025-06-11 23:17:29] |
| User610117 - Posts: 47 |
Hi, I have searched the forums and youtube videos for a way to do this. Interactive Brokers gave me 2 different sign-on's for trader workstation because they separated my personal accounts from my business accounts. Is there a way to show these accounts in 1 sierra chart sign on to be able to trade them all at once? I've read articles on opening a second instance, but someone wrote they can only trade in 1 of those accounts that way. Would appreciate any help you can provide. Thank you as usual! Date Time Of Last Edit: 2025-06-11 23:43:01
| [2025-06-12 13:44:28] |
| Sierra_Chart Engineering - Posts: 25483 |
No this will not be possible: Is there a way to show these accounts in 1 sierra chart sign on to be able to trade them all at once?
The only way to do this is to run two separate instances of Trader Workstation and 2 separate installations of Sierra Chart. Refer to: Using Multiple Data and Trading Services at the Same Time Each installation of Sierra Chart will connect to each instance of Trader Workstation. Refer to: Interactive Brokers Trading Service: Using Multiple Sierra Chart Instances with TWS Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-06-12 13:46:31
