Date/Time: Wed, 25 Nov 2026 21:05:58 +0000
Simulated P&L Not Updating Correctly on Treasury Spreads (ICS's)
View Count: 534
| [2025-06-11 17:09:43] |
| trader913 - Posts: 8 |
Good day Support, I'm sim trading the NOB spread (U25.FUT_SPREAD.CBOT), but the P&L only updates in $0.01 increments, regardless of price movement (in the photo I've attached I've made a consecutive amount of trades to test any changes to see if any changes it isn't increments of 0.11c but 11 trades where the loss result was 0.01c/trade), when it should be $15.625/tick currency increments. I've attempted so far to change symbol settings and adjust the tick size, price display format, and currency value per tick but nothing seems to be changing. If you could help me to fix this pnl display issue it would be greatly appreciated. Thanks |
| [2025-06-13 17:07:26] |
| Sierra_Chart Engineering - Posts: 25483 |
First thing is to update to the current version of Sierra Chart for proper support for these particular spreads: Software Download: Fast Update We have now set the symbol parameters correctly for this symbol. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Finally, apply the Symbol Settings to the chart: Global Symbol Settings: Applying Global Symbol Settings to Existing Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
